Szukam do garbusa pojemność 1192 1966 rok danych: G, O1, O2 P2
http://www.globalcar.com/datasheet/Volkswagen/Volkswagen_1200_Beetle.htm
Volkswagen 1200 Beetle
Bodywork
Type: 4/5S SAL
Number of doors: 2
Dimensions
Wheelbase: 2400 mm 94.48 in
Track front: 1308 mm 51.49 in
Track rear: 1289 mm 50.74 in
Length: 4064 mm 160.00 in
Width: 1537 mm 60.51 in
Ground clearance: 152 mm 5.98 in
Kerb weight: 739 kg 1629.21 lb
Fuel capacity: 39.8 l 10.51 US gal
Engine
Type: 4-F
OHV
2 valves per cylinder
Bore x stroke: 77.00 mm. × 64.00 mm.
Bore / stroke ratio: 1.2
Displacement: 1192 cc 72.74 cu in
Compression: 7
Fuel system: 1 So carb
Aspiration: Normal
Catalytic Converter: N
Max. output: 40.5 PS (40 bph) (29.8 kW) @ 3900 rpm
Max. torque: 88 Nm (64.9 lbft) (8.9 kgm) @ 2400 rpm
Coolant: Air
Specific torque: N/A
