Sym gts evo 300 Potrzebne DMC i naciski
Witam.
Znów mam wynalazek na stacji
Skuter SYM gts evo300 z GB a tam w dowodzie to nic nie ma.
Potrzebuję Naciski i DMC reszte już znalazłem.
Z góry dzięki za pomoc.
[ Dodano: 23-06-2014, 15:39 ]
DMC już mam 342kg
Jeszcze naciski by się przydały
SPECIFICATIONS
GTS/JOYMAX 300i evo
OverallLength (mm) 2165
OverallWidth (mm) 870
OverallHeight (mm) 1395
SeatHeight 755
WheelBase (mm) 1495
GroundClearance (mm) 135
WeightFront (kg) 79
WeightRear (kg) 111
SpecsWeight (kg) 190
Transmission C.V.T., auto speed change
PrimaryReduction belt, 2.3 ~ 0.80
FinalReduction gear, 7.42
EngineType 4-stroke,4V,water cooled
Cylinder single cylinder
Displacement 263.7
FuelSystem EFI(C.L.)
FuelControl O.H.C.
MaxHorsepower 17.15Kw/7500rpm
MaxTorque 24.08Nm/5500rpm
FuelType unlead gasoline
ExhaustEmissionCo < 2.0
ExhaustEmissionHC < 0.3
ExhaustEmissionHCNOx < 0.15
Noise (dB) < 80
Alternator 338 W / 5000 rpm
BatteryVoltage 12 V 10Ah
HeadlightLamp 12 V 55W / 55W× 1
FrontPositionLamp LED
TaillightStoplightLamp LED
FrontTurningSignalLight 12 V 21W× 2
RearTurningSignalLight 12 V 21W× 2
LicensePlateLamps 12 V 5W× 1
RearReflector 1
FrameType pipe under bone
FrameMaterial steel
FrontSuspension telescopic fork
RearSuspension unit swing
FrontRim aluminum
RearRim aluminum
FrontTireType tubeless
FrontTireDimensions 110 /90-13 56P
RearTireType tubeless
RearTireDimensions 130 /70-13 57P
FrontBrakes disk
FrontBrakeDiameter (mm) φ240
RearBrakes disk
RearBrakeDiameter (mm) φ220
FuelCapacity (l) 12
MaxSpeed 128
FuelConsumption (km/l) > 40
ClimbingCapacity (deg) > 27
http://translate.google.pl/translate?hl=pl&sl=en&u=http://www.sym-global.com/&prev=/search%3Fq%3Dsym%2Bcom%26newwindow%3D1
